turn signals and brake lights are not working
185,000 MILES • 5.3L • 4WD
CLARA SHOPE COMER
Brake lights and turn signals stop working. I have tail lights and running lights.
Mar 9, 2017 at 12:48 PM
HMAC300
  • 48,601 POSTS
assuming you have check the bulbs, then it may be a turn signal switch or brake light switch. check fuses as well. check fuses and relay in picture first. however, it could be that. if fuse blows again there is a short in system.
Mar 9, 2017 at 11:00 PM
