light on information center on dash
2006 LINCOLN NAVIGATOR
128,300 MILES • 5.4L • V8 • 4WD • AUTOMATIC
DAV206
the light on information center is a led about two inches long one inch tall it was working then went out then started working again but quit again. could it be a bad ground? also interior lights dont come on but you can turn them on manually. thank you
Nov 26, 2016 at 10:45 PM
HMAC300
  • 48,601 POSTS
check fuse twenty four and battery saver relay in central junction box. it may be an instrument cluster problem however as there is a micro processor and relay in it which are not changeable but can be rebuilt.
Nov 27, 2016 at 12:34 AM
