service stable trac light on dash?
80,000 MILES • 6.5L • TURBO • 4WD • AUTOMATIC
WILLIAM123ANITA
service stable trac.
Nov 1, 2023 at 3:52 AM
  • 110,248 POSTS
The stability control can be affected by a few things. For example, a faulty wheel speed sensor can cause it. Even low brake fluid.
What I recommend is this. Since there are a few different possibilities, we need to scan the can-bus to retrieve codes. CAN stands for controller area network.
Basically, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them. In this case, it will likely be the anti-lock brake control module.
Here is a link that explains how to perform the scan:
This is where I would start. Otherwise, it will become a guessing game or involve independent tests that will take extended periods of time.
Let me know if this is something you can do or have done.
Nov 1, 2023 at 1:29 PM
