liftgate will not open
199,999 MILES
RICKSEWELL
no power to under hood fuse 44, but fuse is not blown. several other fuses in same area no power either.
Mar 8, 2022 at 2:16 AM
  • 110,248 POSTS
I just went through the power distribution schematics and feel nearly as confused as I did when I started. LOL The fuse legend for the under-hood fuse box indicates exactly what you said, fuse 44/liftgate. When I go to the schematics, there is no fuse 44 indicated.
So, I located the actuator for the liftgate. I worked backward from the actuator, and nothing indicates fuse 44, but there are fuses that are 15 amp (unidentified). I went further back and found that power to the 15-amp unidentified fuses is supplied via fuse 66 (stud 2) 30 amp.
I attached a pic of the fuse box and highlighted fuse 66. Check that fuse and see if there is power.
Let me know what you find.
Mar 8, 2022 at 11:39 AM
