Lifters
2003 CHRYSLER 300
115,000 MILES • 3.5L • V6 • FWD • AUTOMATIC
TAMMYMOORE
I need to replace my lifters and cannot remove them. can you tell me how to get them out? Thank you.
Aug 20, 2016 at 5:33 AM
HMAC300
  • 48,601 POSTS
it is too much for us to copy and paste, but you need to remove the rocker arms to gain access to lifters then they should come right out. if you want to rent a manual it is available here on site and you can print it out what you need.
Aug 20, 2016 at 6:11 AM
TAMMYMOORE
They wont come out. they must be stuck.
Aug 20, 2016 at 7:28 AM
  • 31,937 POSTS
Often old lifters get a carbon build up around the base of the lifter, there is a tool that hooks into the top of the lifter that acts as a puller and you can work the lifter up and down while spraying a lube spray around the lifter to try and soften the carbon.
Aug 20, 2016 at 10:15 PM
