My truck is emitting white colored smoke
71,439 MILES • V8 • TURBO • 4WD • MANUAL
MIC1953KY
It also has a pretty severe shake especially idling. Lifter problem or not?
Jul 18, 2020 at 9:32 AM
  • 110,248 POSTS
White smoke usually indicates that coolant is entering the combustion chamber and burning with the fuel. This is usually the result of a faulty head gasket.
Has the coolant level been getting low? Is there any indication of the coolant mixing with the engine oil?
Take a look through this link and see if anything mirrors what you are seeing.
Let me know what you find. I can provide the directions for gasket replacement if needed. Also, you may want to scan the computer to see if there is a code specific to one or more cylinders. Here is a quick video showing how it's done.
https://youtu.be/Cg1WO0UKIYM
Here is a list of obd2 codes you can reference:
https://www.2carpros.com/trouble_codes/obd2
Jul 18, 2020 at 10:00 AM
