Lifter assembly
290,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
BRITOMARTIS HECTATES TILLERY
  • 12 POSTS
I need to get to the gaskets on the bottom of the lifter assembly. how much torque does the assembly require?
May 20, 2019 at 11:59 AM
  • 55,694 POSTS
Here is a video to help you use a torque wrench correctly and the specs:
https://youtu.be/juOClONIWeY
TIGHTENING SPECIFICATIONS
8 mm bolts .................... 22 Nm (16 ft. lbs.)
6 mm bolts .................... 12 Nm (107 in. lbs.)
Please let us know if you need anything else to get the problem fixed. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
May 23, 2019 at 5:13 AM
  • 12 POSTS
I will send video tomorrow afternoon.
May 25, 2019 at 11:40 AM
  • 55,694 POSTS
That would be great! Please let me know
May 26, 2019 at 6:35 AM
