Thinking of installing two inch lift kit to clear bad roads
31,000 MILES • 2.0L • 2WD • AUTOMATIC
TIM PINKERTON
I have purchased the car listed above GLS. Where I live the roads are in poor condition and many are dirt/gravel roads. It has been suggested I put a two inch lift kit on it. The lift kit I see online is affordable ($150.00 to $200.00). However, someone also said it will need a new suspension and that add a lot of money to the equation. Any advice?
Jul 23, 2018 at 4:21 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Do you happen to have a picture of the Lift Kit or the brand name?
Thanks for using 2CarPros.
Danny-
Jul 23, 2018 at 5:31 AM
TIM PINKERTON
Hi Danny,
Thanks for your reply. These are the two kits that have been recommended to me: http://www.metalnerd.com/catalog/search?keyword=lift+kit+beetle.
A two inch lift would be preferred, but if that would require additional work, I would settle for a one inch.
I am also open to any recommendations.
I had a Beetle in the 1970's but my uncle did all the work on it. I am reliving my teenage years. :)
Jul 23, 2018 at 11:04 PM
DANNY L
  • 5,648 POSTS
Hello again.
I am doing a little research on this so I will get back to you this afternoon.
Danny-
Jul 24, 2018 at 12:57 AM
TIM PINKERTON
Thanks Danny. I appreciate your help!
Jul 24, 2018 at 4:06 AM
DANNY L
  • 5,648 POSTS
Hello again Tim.
I actually talked to the owner (Pennsylvania, USA)and he sent me an email with detailed instructions. It is a pretty simple bolt-on kit! It uses the small spacer installed at the top of the front struts between the strut and bearing plate. (coil spring compressor needed) Note: That would be a good time to replace struts if old/worn. The rear just uses that larger spacer between shock and frame. The only difference is on the two inch kit you add a bracket to use the same length factory shock. Pretty simple. I have attached pictures from his instruction manual showing where the spacers go. I forgot a picture of the two inch shock bracket but I can get it if needed to show you. Hope this helps and feel free to ask any questions if needed.Thanks for using 2CarPros.
P.S. My first car when I was twlve years old was a 1966 VW Baja Bug! After building it I won Bug-O-Rama 23 at the age of sixteen. (picture attached)
Jul 24, 2018 at 3:25 PM
TIM PINKERTON
Hi Danny! You are awesome! Thanks so much for your efforts! This question certainly was given to the right guy! You are Baja Bug looks fantastic! What an accomplishment for a young kid! Wish you could come here to lift my bug!
My uncle loved to tinker on my 1968 bug and he welded a wind-up key on the back. :) Unfortunately, all the pictures were lost in a house flood.
I will order the two inch lift parts and if my mechanics have any questions. I will write back to you.
Thanks again! You have been a great help!
Jul 25, 2018 at 12:31 AM
DANNY L
  • 5,648 POSTS
Hello again Tim.
You are welcome! Feel free to ask us here any questions. Let me know how it turns out. Thanks again for using 2CarPros.
Danny-
P.S. Here is one last engine picture.
Jul 25, 2018 at 2:41 AM
