License plate lights turn off when brakes are applied
200,000 MILES • 4 CYL • FWD • AUTOMATIC
DELNLARRY
  • 6 POSTS
When the brakes are not pressed, all lights seem to work properly. When the brakes are pressed, all lights seem to continue to work properly, but the license plate lights turn off. Ease off on the brakes and the license plate lights work again.
Jan 18, 2014 at 1:26 AM
SATURNTECH9
  • 30,869 POSTS
Have you tried making sure you have the correct brake bulbs in the brake sockets?
Jan 18, 2014 at 2:59 AM
DELNLARRY
  • 6 POSTS
Yes, I did that. In fact, I bought new brake light bulbs just in case one or both was defective. No change in the problem. They are definitely the correct bulbs.
Jan 21, 2014 at 1:44 AM
SATURNTECH9
  • 30,869 POSTS
Do you have a multi meter to do some testing?
Jan 21, 2014 at 4:07 AM
DELNLARRY
  • 6 POSTS
Got the problem fixed. Turned out to be a broken wire in the wiring harness in the trunk area. thanks.
Jan 23, 2014 at 6:16 AM
SATURNTECH9
  • 30,869 POSTS
Was it on the passenger side behind trunk hinge?
Jan 23, 2014 at 6:27 AM
DELNLARRY
  • 6 POSTS
I think so. A friend found it and fixed it for me, so I'm not exactly sure. But is was in a bend in the wiring harness. In fact, the other wires in the grouping were all pinched, so he spliced in some extra wiring on all the wires to make them longer and, hence, less likely to pinch.
Jan 24, 2014 at 5:53 AM
SATURNTECH9
  • 30,869 POSTS
I have seen some of the lexuses do that but the brake light was just inop.
Jan 24, 2014 at 7:11 AM
DELNLARRY
  • 6 POSTS
Now that you mention it, I think he said there also was a problem with the brake lights going dim or out when the brake was pressed, although I did not notice that when I was trying to figure out the problem.
Jan 24, 2014 at 8:04 AM
SATURNTECH9
  • 30,869 POSTS
Glad to hear you got it fixed.
Jan 24, 2014 at 8:08 AM
DELNLARRY
  • 6 POSTS
Me, too. Now I can get it past safety inspection. Thanks.
Jan 24, 2014 at 8:20 AM
