license plate light is not working
178,000 MILES
JUSTIN_IRVIN420
my plate light quit out i checked the fuses and there all good i tested it and wasnt even getting a full volt could you plz help me out i ran a wire from my tail light to my license plate temporarallybut i need it fixed plz help
Jul 17, 2013 at 7:04 AM
CJ MEDEVAC
  • 11,000 POSTS
I "WAS" GONNA GET YOU A WIRING DIAGRAM FOR YOUR "EXTERIOR LIGHTS"....SO YOU COULD LOOK THINGS OVER, MAYBE FIND A GROUND THAT WAS LOOSE OR BROKE.
I JUST GLANCED THRU "MITCHELL I"----IN THE "CAMRY LE" SECTION ALONE, THERE ARE OVER 130 SYSTEM WIRING DIAGRAMS.......THEN WE RUN INTO "SPECIFICS"
IN ORDER TO OBTAIN THE CORRECT DIAGRAM FOR YOU, I NEED:
EXACT CAR NOMENCLATURE (ex: LE, LTD, SAHARA, TOWN CAR)
ENGINE SIZE
ANYTHING WEIRD, LIKE, DRL (DAYLIGHT RUNNING LIGHTS) ETC
THESE DIAGRAMS ARE EZ TO READ AND USUALLY LIST LOCATIONS OF STUFF
YOUR TURN
THE MEDIC
Jul 17, 2013 at 8:01 AM
NICOME
Check the wire harness that runs along the left side of the trunk hinge.
The harness moves with the hinge, so you could have a broken wire there.
This is a common problem with this car.
Jul 17, 2013 at 5:55 PM
