License plate bulb assembly
69,000 MILES
EGUNS80
  • 85 POSTS
How do I replace the plug assembly for the license plate
Jul 18, 2025 at 11:00 AM
  • 55,748 POSTS
Start by removing the license plate bulb lens, then the housing will come out as well, just unplug it and plug he new one in and reinstall the lens and you are all set. Check out the images (below). Let us know how it goes
Jul 19, 2025 at 2:52 AM
EGUNS80
  • 85 POSTS
The whole plug and wire will come out that way? I need to replace the whole thing not just the bulb
Jul 19, 2025 at 7:33 AM
  • 55,748 POSTS
Yes, do you see how the lens comes out, the housing will follow it with the wiring. If you have troubles upload an images of the problem as I can walk you through the repair.
Jul 20, 2025 at 3:08 AM
EGUNS80
  • 85 POSTS
Both lights are attached by one plug like in the pic in my first question. How am I supposed to feed the one thru the tailgate?
Jul 20, 2025 at 7:16 AM
  • 55,748 POSTS
I think the housing bolts to the rear of the mounting plate. Did you remove the lens? Can you upload an image so I can see?
Jul 21, 2025 at 3:08 AM
EGUNS80
  • 85 POSTS
They dont have lens covers and the plugs arr all corroded, thats why I need to replace the whole thing as shown here
Jul 21, 2025 at 3:42 AM
  • 55,748 POSTS
Can you take an image of the lenses on the car so I can see?
Jul 21, 2025 at 3:43 AM
