Left hand side Blend Door not working
2014 FORD FUSION
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
RDEBACKER
When A/C on the driver side air is warmer than the passenger side. Manual single zone controls.
Does the car have two blend doors or one?
If two, then when is the LH side actuator located and any replacement hints would be great.
Already check RH side and it appears to be working fine.
Jun 17, 2022 at 7:33 AM
JIS001
  • 3,412 POSTS
I would recommend renting some gauges from your local parts store to check the pressures. Usually, when you're low on refrigerant one side will be cooler than the other. If you are low, recharge with refrigerant that has dye in it. That will help you pinpoint any external leaks if you go low again. Here is a link on checking A/C:
https://www.2carpros.com/articles/air-conditioner-leak-detection
Jun 17, 2022 at 12:42 PM
