The code:
P1401 - Sub Throttle Position Sensor Range/Performance Problem
The sub throttle position sensor is used for traction control. See diagnostics procedure for that DTC attached.
This vehicle is equipped with a throttle position sensor, a throttle control motor and a accelerator pedal position sensor. They are all connected to the either side of the throttle body. See diagrams below for position of each of these components.
https://www.2carpros.com/articles/how-a-throttle-body-works
I have attached the diagrams for your reference.
Images (Click to enlarge)
Aug 20, 2021 at 11:37 AM
