1996 Lexus SC 400 fog light burned ouit
1996 LEXUS SC 400
11,200 MILES • V8 • 2WD • AUTOMATIC
ZMARGO
Passenger side fog light is out. I assume it's just the
bulb (12v 55W H3). Have dismantled lower shroud
to get at light that I assume has to be taken out
to replace the bulb. Have taken off the back 2
washer nuts and fixture still won't budge.
Dealer says bring it in and will replace it for $35.00
What can you suggest?
Feb 6, 2010 at 6:55 AM
2CARPRO JACK
  • 11,533 POSTS
That style of bulb is usually held in with a wire retainer, removal of the light shouldnt be necessary.If you can acccess the back of the light, see if there is a cover to remove to gain access to the retainer and bulb
Feb 8, 2010 at 11:48 PM
