1995 Lexus SC 400 Radiator Fan
80,000 MILES • V8 • 2WD • AUTOMATIC
RFSCHU
Ever since I had the Hydraulic Seal changed (part # 90099-01581?) the radiator fan is always on, even when I start the engine without the a/c on in the morning. The revolutions of the fan seem to change with the engine speed. I am almost certain that the fan was not always on before, and would come on only intermittently. I have had the car at the local Toyota dealer several times for long periods at a time, but they seem to be unable to find the cause. Can you help?
Oct 22, 2009 at 1:21 PM
  • 110,248 POSTS
You are correct. THe fan shouldn't run all of the time. Have they checked the fan relay and the temp sending unit?
Nov 25, 2009 at 2:59 PM
