1994 Lexus SC 400 Master Cylinder
1994 LEXUS SC 400
148,000 MILES • V8 • 2WD • AUTOMATIC
SHYHEEM
When I press My brake pedal it goes to the floor when the cars on.... It Builds Pressure when the cars off when I press it..... some say its air in the system I should bleed the abs.... some say its the actuator..... some say its a traction control/ brake system computer recall..... some say its the master cylinder....
Apr 7, 2009 at 1:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
There are no recalls nor are there any TSBs (Technical Service Bulletin) for this issue. However, the first and easiest place to start troubleshooting is by bleeding the brake system. Post results of bleeding system and I will follow up.
Thanks for using 2CarPros.com!
Apr 7, 2009 at 7:31 PM
