1992 Lexus SC 400 ROUGH/MISSING ENGINE
16,700 MILES • V8 • 2WD • AUTOMATIC
JAPAN748
Runs rough/missing when engine is cold, once warm
engine runs fine.
Aug 6, 2010 at 4:31 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Aug 6, 2010 at 7:43 PM
