1992 Lexus SC 400 Replace the timing belt
CLIFFONSO
1992 Lexus SC 400 V8 Front Wheel Drive Automatic
In the process of replacing the timing belt, something happened or something moved and we can't get the timing marks on the belt to line up with the ones on the cam gears. how do I start all over and get everything in time?
Cliffonso
May 10, 2010 at 9:27 AM
  • 75,988 POSTS
Put the engine no.1 piston on its compression then line the cam and crank markings as you see in the book then slap the belt on.
May 10, 2010 at 9:36 AM
