1995 Lexus SC 300 vehicle starting
100,000 MILES • 6 CYL • FWD • AUTOMATIC
RUSSELLMI36
What is the problem when the car seems do drags or hesitates to start is it the starter or alternator the battery is good 2 or 3 times to turn it comes on then.
Nov 27, 2009 at 1:08 AM
  • 75,988 POSTS
Do you hear a buzzing noise when cranking it over if so the starter overrunning clutch is slipping if not and battery/connections are okay -could be the starter itself get it load tested to confirm
Nov 27, 2009 at 8:50 PM
