Hi, I just wanted to know if I can fix removing water resedue in the headlight unit? Not outside of the headlight.
Feb 2, 2009 at 6:50 PM
MOODYGJ
MEMBER
1 POST
On the Lexus Forum Web Site I found step by step instructions on how to take headlight apart, clean and put back together and seal so no moisture can get inside headlight. This is a common trait with the SC 300. If you are unable to locate repair instructions on Lexus Forum Web Site, Let me know and I will locate for you.
Jan 23, 2010 at 2:17 AM
