2007 Lexus RX 350 HIDE WIRING
ATLANTICTAILSPIN
  • 2007 LEXUS RX 350
Interior problem
2007 Lexus RX 350 6 cyl All Wheel Drive Automatic
I have a SIRIUS radio receiver and want to hide the wiring beneathe the dash or around the sideof the dash. How do I or do I need to remove a part of the dash? Can I "string" it through some openings?
Wednesday, January 7th, 2009 AT 4:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
Satellite radio wiring is relatively small. It should slip into the cracks and grooves of the dash that is not visible to the eye at a normal seating position. Just ensure that the wiring is insulated good and will not be in any spot that may damage the wiring (i.E. Door jambs). You will just have to work with the wire to get it exactly the way you want it. If you do want removal instructions for the dash board just let me know, but that is a lot of work to hide a little wire, probably better off tucking it into the cracks as stated above.
Hope this helps.
Thanks for using 2carpros. Com!
Thursday, January 8th, 2009 AT 2:16 AM
