2004 Lexus RX 330 power steering squeal
2004 LEXUS RX 330
42,000 MILES • 4 CYL • AWD • AUTOMATIC
MCFANCY
thank you first of all. when the car is cold and first started the power sterring squeals when the wheels are turned. afer the engine warms upin a couple minutes the squeal goes away...any ideas?
Jan 31, 2009 at 2:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello. You need to inspect your power steering fluid. Ensure it is full. If it is a little low, this will cause the pump to whine while turning until fluid has warmed up a bit. If the fluid level is OK then suspect the pump is faulty and going bad.
Thanks for using 2CarPros.com!
Jan 31, 2009 at 2:27 PM
