2004 Lexus RX 330 cd player malfuntion
2004 LEXUS RX 330
77,560 MILES • 6 CYL • AWD • AUTOMATIC
PANDA25VINA
Hello!. I would like to ask a question in regards of the cd player malfuntion of the above vehicle. The cd player was working fine from last night but this morning it show the word "ERROR 3" I did reset by checking the fuse and disconect the battery power but it's still not working. What's is the reason and how's happening?. I would like to fix it my self with your professional assist in this matter. Please send me the pertinent information asap because we can not drive a car with out a cd player (it sleepy at night when we drive a long distance). Thank you very much for your time and help.
May 6, 2009 at 9:47 AM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
If it is a cartridge style of CD palyer, try ejecting it and being sure that there are no discs jammed part way in or out and that hte levers are working correctly on the cartridge.If ok you may have to do a diagnostic on it.
1-turn off audio system
2-put key in acc position
3-while pressing buttons 1&6 press the"disc" button 3 times
4-should beep 3 times, takes about 40 seconds to do the test, then it should give a trouble code
May 8, 2009 at 7:48 AM
OTTOS33
I completed the stated action on my cd, after the beeps, my display was full of CODES??? How do you read them and where can you ind out what they mean?? Thanks
Dec 31, 2013 at 11:41 AM
