I brought my rx 330 to the dealer because the brake light came on. They said the brake fluid level was low and that fluid was found inside the power brake booster. I was also told to fix the problem the brake master cylinder and power booster assembly would need to be replaced. Estimated cost of repair was over $1000. Does that seem right?
Oct 30, 2009 at 10:25 AM
