2001 Lexus RX 300 speed sensor
ANTHONY MAZZIOTTI
  • 6 POSTS
2001 Lexus RX 300
how to install, or chek the old one
Aug 3, 2009 at 1:54 AM
DOCFIXIT
  • 18,828 POSTS
Hi No way to check without a scanner to see if output signal is equal to rpm. Diagram shows location one bolt and it's out. Do you have a code for turbine sensor fault? THanks for donate
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_11.jpg
Aug 3, 2009 at 5:43 AM
ANTHONY MAZZIOTTI
  • 6 POSTS
1st why do I have to keep login in when I'm answering your tech who sent me a message. I had to log in twice, and still don't have the right answer. 2nd the drawing he is showing me , I have no idea what it is. I'm talking about a speed sensor on the left rear wheel of a 2001 lexus RX 300 this looks nothing like it. I keep paying and I'm not getting the right answers. The techs take forever and give you the wrong answer. I don't mind paying but , give me the right answer I'm looking for.
Aug 3, 2009 at 10:32 AM
DOCFIXIT
  • 18,828 POSTS
Well when your question is vague I went for Vehicle speed sensor not the ABS wheel speed. Now if you told me that first you would have gotten the right info. Thes diagrams will illustrate removal
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_17.jpg
https://images.2carpros.com/forum/automotive_pictures/198357_Grafic_3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_21.jpg
Testing must be done with Lexus ABS scanner
Aug 4, 2009 at 1:19 AM
