2001 Lexus RX 300 Rotors may need turning
2001 LEXUS RX 300
HAW6872
Brakes problem
2001 Lexus RX 300 Two Wheel Drive 82000 miles
When I apply brakes I get a jerkingor bumpy
uneven feel in steering wheel.
I have experienced this in other cars I have owned and turning the rotors corrected the problem.
I also replace the brake pads with usage mileage still on the pads.
MY feelings are that when rotors and pads get hot and you run through cold water this has a tendacy to harm rotors. I have corrected this by turning rotors in past.
The RX300 may require other solution for this problem sine it is considered a lurury vehicle.
Thanks for your help,
Alan Weaver
Feb 14, 2009 at 10:43 AM
The only way to tell is to mike the rotors to see if it needs resurfacing
Feb 14, 2009 at 12:31 PM
