2001 Lexus RX 300 REAR SHAKING
154,883 MILES • 6 CYL • 4WD • AUTOMATIC
ANONYMOUSME419
my car is fine, engine-wise, but ive noticed that while im driving, the rear part shakes, it sounds like its coming from underneath now that im listening to it. i thought at first it was coming from the extra wheel kept in the back but i once removed everything from the back and tightened the bolt holding the wheel down then drove around but it still made that same rumbling sound. so i concluded it must be coming from underneath the car.
the funny thing about these shakes is it only comes on when i go over small bumps and grooves in the road but if i go over a major bump or pothole, it just makes the normal bump sound or a lil shake or rumble, much smaller than if i went over a small bump.
also, my gas pedal squeaks, my steering squeaks a lil when i turn it a lil too quickly, my car doors rattle when the speakers are too loud but im guessing that is normal....[img:9721e2175a]http://www.2carpros.com/forum/automotive_pictures/263109_DSC05304_1.jpg[/img:9721e2175a]
Oct 28, 2008 at 12:44 PM
DLOBI
  • 125 POSTS
HI, You can make those door speakers "thump" eh? :)
The noise from under the rear of the vehicle could be as simple as a loose exaust system.
Have a technition get it up on a hoist and have a look around under there.
Oct 28, 2008 at 1:20 PM
ANONYMOUSME419
I guess...its pretty tempting
Oct 28, 2008 at 1:24 PM
DLOBI
  • 125 POSTS
lol, and if you turn it up high enough you can't hear that noise from under the rear of the car either I suspect :o
Oct 28, 2008 at 1:34 PM
ANONYMOUSME419
Amazingly it does but it also damages my speakers...
Oct 28, 2008 at 2:56 PM
