2001 Lexus RX 300 drivers side window operation
2001 LEXUS RX 300
SONNY211
2001 Lexus RX 300
driver side window will go down by switch,extremely intermittant when switch is used in up direction. sometimes it will start to go up, then drive back down. when it does work, it will only work every blue moon, not very reliable. when i work the switch up or down i can hear the relays in the switch assy. clicking. motor seems very hot to the touch, any help in this problem would be very helpful . many thanks
mitch
Sep 20, 2009 at 4:11 PM
LEX SO CAL
  • 27 POSTS
mitch we need to start by repl switches master
the problem is they are expensive send me an e mail
i may be able to help you find a set
Sep 21, 2009 at 4:42 PM
