2001 Lexus RX 300 anti skid
ANTHONY MAZZIOTTI
  • 6 POSTS
Brakes problem
2001 Lexus RX 300 6 cyl All Wheel Drive Automatic
I just replaced the Left rear wheel bearing, now the anti skid light comes on and the car boog down then goes . once it goes it's fine till you stop or turn, then it boogs and chatters.
Aug 1, 2009 at 6:54 AM
ANTHONY MAZZIOTTI
  • 6 POSTS
[quote:79644bacc6="anthony mazziotti"]Brakes problem
I just replaced the Left rear wheel bearing, now the anti skid light comes on and the car boog down then goes . once it goes it's fine till you stop or turn, then it boogs and chatters.[/quote:79644bacc6]
Aug 1, 2009 at 7:30 AM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_438.jpg
Check for damaged ABS speed sensor pull codes good luck
Aug 1, 2009 at 3:56 PM
ANTHONY MAZZIOTTI
  • 6 POSTS
tried that , OK
Aug 2, 2009 at 3:08 AM
ANTHONY MAZZIOTTI
  • 6 POSTS
that was the first thing I checked , there was no damage to it.
Aug 2, 2009 at 3:14 AM
BMRFIXIT
  • 19,053 POSTS
Use an ohm meter and check it
disconnect it and ohm check for continuity
and need to have the ABS system check for codes
Aug 2, 2009 at 12:34 PM
