2000 Lexus RX 300 wrong key locked up theft system
107,770 MILES • 6 CYL • AWD • AUTOMATIC
LEXUSRX
Hello
My wife and i both own a lexus.
I accidently used my lexus key (es) to try to start my wife's car(rx). Now her key will not turn in the ignition and steering wheel will not turn. I tried jiggling the steering wheel back and forth and turning the key at the same time. It will also not come out of park. I disconnected and reconnected the positive battery connection, but it didn't do any good. I live 60 miles from the nearest lexus dealer. Any suggestions? Thank You
Jan 27, 2008 at 8:38 AM
MIKE H R
  • 3,094 POSTS
I am not to good with the alarms for those cars, but you can try disconnecting the positive side of the battery. without the positive side of the battery hooked up use a jumper wire touch the positve cable that you took off to the ground. after a minutes disconnect the jumper wire. hook the battery back up, wait a minute then try her key, you might have to put it in and out a couple of times. There are other moderators tha know more about it but it is something you can try.
ps. make sure the battery has a good charge.
Jan 27, 2008 at 12:24 PM
LOSTINMARS
  • 222 POSTS
the alarm will not keep the key from physically turning. chances are you might of damaged the ignition lock cylinder.
Jan 28, 2008 at 12:35 PM
MIKE H R
  • 3,094 POSTS
I looked up service bultein and did not find any in reference to resetting the ignition. I did find that the key has a computer chip in it that locks the ignition system of the vehicle. try using the key with out any other keys around.
https://images.2carpros.com/forum/automotive_pictures/54223_hs_1.jpg
Jan 29, 2008 at 2:02 AM
JOHN_DEERE_BOY
How did you solve your problem? I just did the same thing. I mistakenly put the key to my 2002 ES into my wife's 2004 RX and ended up locking the theft system. Please let me know how you solved the problem.
Feb 15, 2008 at 1:11 PM
LEXUSRX
Hello
My garage(not a lexus dealer) told me to use wd40. I used the red spray nozzle and sprayed some in the ignition, put my wife's key in and it turned instantly.
Try it and good luck.
Feb 16, 2008 at 12:55 PM
MIKE H R
  • 3,094 POSTS
You were lucky, I was talking to a locksmith that deals with just automobiles the other day. Inside the ignition switch there is a split chip. When someone uses a diferent key it breaks off a little piece inside the ignition making it so the igniton is inoperative. The piece is no bigger than a tip of a toothpick. you are lucky that the chip did not break off completly .
Feb 29, 2008 at 6:29 AM
