when i pull on the lever to open the gas tank door it will not open. The lever and cable work fine yet the door does not swing open to clear the plastic tab. It takes two people, one to pull the lever and another to pull on the gas tank door. Seems there should be a spring or something that allows the door to swing free of the tab. Is there a spring broken on the door?
Feb 10, 2009 at 9:35 PM
