2000 Lexus RX 300 driver side window
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
TAMMYJTITUS
THE DRIVER SIDE WINDOW IS SOMETIMES NOT ROLLING BACK UP, I HAVE TO TRY IT SEVERAL TIMES BEFORE IT WILL ROLL UP. IT SEEMS TO BE GETTING WORSE. I AM TAKING IT TO REPAIR SHOP, I NEEDT TO KNOW WHAT IT NEEDS SO I DO NOT GET RIPPED OFF. THANKYOU FOR YOUR TIME! SINCERELY,TAMMY TITUS
Nov 3, 2010 at 8:37 AM
SATURNTECH9
  • 30,869 POSTS
It's most likely going to be your window motor/regulator or it could be your window switch.Without testing for power and ground at the motor when it doesn't work then you won't know.
Nov 3, 2010 at 8:51 AM
