2000 Lexus RX 300 Computer Code P0171
108,000 MILES • 6 CYL • AWD • AUTOMATIC
JUST A DUMB GIRL
I'm driving to Chicago from DC and don't have time to take the care to another mechanic. Original mechanic pulled up a P0171 code which indicates need to replace the MAF--after he first replaced both oxygen sensors for $1000 and it still didn't fix the problem: engine light and track-off light still come on and stay on.
Two questions:
1. Is it safe to drive to Chicago and back?
2. Is it worth putting in the cost of further repair when the car's worth less than $10,000?
This site has been very helpful for a dumb girl like me. Thanks.
Jun 17, 2009 at 1:06 AM
  • 75,988 POSTS
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
Jun 17, 2009 at 1:10 AM
JUST A DUMB GIRL
Dear rasmataz-thanks for the quick "auto reponse" but you didn't answer my questions:
Is it worth putting in the SS to repair?
I guess I should have donated more.
Jun 17, 2009 at 1:43 AM
  • 75,988 POSTS
Get the car rescanned again for code/s-To answer if it will take you there and back its hard to say. Cost of repair depends on what needs fixing that's causing the lean condition.
You need to get the components I've mentioned earlier checked one by one-I believe its worth fixing it
Jun 17, 2009 at 1:56 AM
JUST A DUMB GIRL
I appeciate your time.
Jun 17, 2009 at 2:04 AM
