1999 Lexus RX 300 Transmission repairs
JONBELL
Transmission problem
1999 Lexus RX 300 All Wheel Drive Automatic 115000 miles
Wondering what would happen if car with slipping transmission had filter and fluid changed - could car become temporarily "fixed" or drivable? I've heard that this is a "mask" and not a "fix" - your thoughts? What about adding certain additives to the fluid as well; what could the net effect of that be?
Dec 23, 2009 at 7:37 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated changeing the filter and fluid on a trans already slipping tends to make the slip worse and the trans will not shift at all sooner .. adding a trans slip addative can help in the short term .. it all depends on how bad the slip is ? Basically the only real fix is to have the transmission repaired .. I would not advise a filter and fluid service at all ! Hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_2carxmas2_24.jpg
Dec 23, 2009 at 9:03 PM
