1999 Lexus RX 300 timming belt / low oil preshure
RPNAPLES
Engine Mechanical problem
1999 Lexus RX 300 6 cyl Four Wheel Drive Automatic 148k miles
replaced belt after engine stoped on my wife. engine started and ran fine (after puting 3 quarts of oil) drove around fine. Gave back to my wife, she drove 15 miles and it hapened again. she stated the oil light came on and she tried to make it home, 2 miles later, same symptoms. I would guess belt jumped again. this time (maybe last time also) she discribed engine started running poor and no power, cams getting sqweezed from lack of oil fluid to the head? Oil sludge? now after alot of research I guess the engine is prone to it. If im on the rite track, replace oil pump? manual also talks about filters in the vvi system ?
Jul 27, 2008 at 6:44 AM
RPNAPLES
You know for a sight devoted to helpin people with car questions, There has not been any help, just critisizisum. I guess I will do what I should have done in the first place, just fix it the best way I know how and forget you and your sight.
Aug 10, 2008 at 5:45 AM
