window on passenger side
LEXUS
CHEKA
the button for the window on the passenger side in the front does not work. only the driver can put the window up and down. what could the problem be and about how much to repair it? lexus es 300 1994
Feb 15, 2007 at 1:48 AM
MIKE H R
  • 3,094 POSTS
the problem should be in the passenger window control. first check on the driver side the window lock is working. remove the window switch. check for loose or dirty conections. if the problem still
happens then the switch is bad. check with junp yards or buy a new switch from a local auto store and installing should take care of the problem.
Feb 16, 2007 at 9:59 AM
