2005 Lexus RX330 Early Rotor Turning
LEXUS
DLANCASTER
I have a 2005 LEXUS RX330 with 23,000lbs miles and just had to have the rotors turned on the braking system. I was told by the dealer that this was normal and could expect to have this done every 20-23,000lbs. Is this true???
Apr 24, 2006 at 11:46 PM
LOSONE
  • 1,616 POSTS
No that is not correct. First of all the rotors aren't designed to be turned because they are made of composite material with about 15 thousands of hard material. If you turn below that amount you run into softer material Then the 20K figure is about right.
I have replaced front pads on a Lexus with over 100K on the rotors and they didn't need turning. The rule on thet kind of car is to replace the front pads every 25 to 30K and the rotors will never be damaged. I hope I have answered your questions. Good Luck
Apr 25, 2006 at 4:20 AM
Suggested Repair
Do not machine these composite rotors on a short interval. Replace the front brake pads about every 25,000 to 30,000 miles so the rotors are not damaged. If machining has gone through the roughly 0.015-inch hard surface into softer material, replace the rotors instead of turning them further.
Conversation Summary
The owner of a 2005 Lexus RX330 with about 23,000 miles was told by a dealer that turning the brake rotors was normal and should be expected every 20,000 to 23,000 miles. The expert said that is not correct. These rotors are composite with only about 0.015 inch of hard material, so turning below that exposes softer material. Replacing the front pads every 25,000 to 30,000 miles should prevent rotor damage, and rotors can last well over 100,000 miles without being turned.
