1991 lexus es250 6 cyl. wont start.
1991 LEXUS
KARMIE93
It doesnt crank. I took the starter in Advance Auto and it checked ok. It has good ground and battery power. Is there a relay or fuse that I need to check?
This problem occured one day when I was starting it and the key slipped in my hand while i was turning it to start. It was trurning over until it momentarily slipped while i turnng the key.
Jan 14, 2007 at 8:15 AM
CARUNDELL
  • 602 POSTS
[quote:393e5c6153="Karmie93"]It doesnt crank. I took the starter in Advance Auto and it checked ok. It has good ground and battery power. Is there a relay or fuse that I need to check?
This problem occured one day when I was starting it and the key slipped in my hand while i was turning it to start. It was trurning over until it momentarily slipped while i turnng the key.[/quote:393e5c6153]
Hey karmie'
There should be a relay and fuse in the underhood electrical center. There was also an issue with the ignition switches on that vehicle too. Let us know
chris
Jan 14, 2007 at 9:08 PM
KARMIE93
Thanks, It wasnt the switch, but there was a relay that was stuck. Main Eng relay. reset it now it works. Ordered a new one to replace. Thanks for the help.
Jan 15, 2007 at 2:19 AM
CARUNDELL
  • 602 POSTS
Great!! glad to help!
Chris
Jan 15, 2007 at 2:38 AM
