1999 Lexus LX 470 Active height control
1999 LEXUS LX 470
93,000 MILES • V8 • 4WD • AUTOMATIC
BAMBO
The height control icon on the dash is stuck on low with a flashing OFF sign underneath. I can't raise the truck. The height control switch by the gear does not turn off the sign.
The automatic leveling is also gone.
There is adequate suspension fluid in the reservoir.
I see no leakage of fluid either.
Please advise.
Thanks.
Jun 28, 2008 at 5:19 AM
NYC.ECHO.LEXUS.TECH
  • 20 POSTS
YOU PROBABLY NEED HIEGHT SENSORS CHECKED AND
ACCUMULATORS SHOULD BE CHECKED FOR OPERATION , MOST LIKELY ITS YOUR HIEGHT SENSORS
HAVE A TECH LOOK FOR DTC'S SET BY THE CHASIS CONTROL ECU
Jan 17, 2009 at 10:04 AM
