1997 Lexus LX 450 what can cause the lexusnot to start?
1997 LEXUS LX 450
EVENOS36
Engine Mechanical problem
1997 Lexus LX 450 6 cyl Four Wheel Drive Automatic
what is the multiple reason a lexus wont start?
Oct 2, 2010 at 2:01 PM
Pick your symptoms
**Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada when key is engage to starting position
Could be a blown fusible link, the starter, starter relay, park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Oct 2, 2010 at 11:25 PM
