1997 Lexus LX FRONT HUBS
POLEBRUSH99
Brakes problem
1997 Lexus LX 6 cyl Four Wheel Drive Automatic
hosw do i remove hubs to change rotor
Sep 28, 2008 at 6:40 AM
2CARPRO JACK
  • 11,533 POSTS
Shouldnt have to remove the hubs to get therotors off that vehicle. There should be 2 phillips head screws holding the rotor on the hub.The screws usually require an impact driver to get them looe, then the rotors come off
Sep 29, 2008 at 7:07 AM
POLEBRUSH99
nope, there are 8 bolts with lock washer type cones, i had to get a piece of brass to pound with so I would'nt ruin threads, then there are 8 more bolts holding hub to rotor, then you can removr the rotor, the 450 XL is all wheele drive.
Sep 29, 2008 at 7:15 AM
2CARPRO JACK
  • 11,533 POSTS
My bad, sorry about that.Here is an exploded view of the front hub assembly, hope it helps.
https://images.2carpros.com/forum/automotive_pictures/1639_lexuslx_1.jpg
Sep 29, 2008 at 8:15 AM
