Just had the rear brakes services now the front brakes needed
HELEN H
Just had the rear brakes services now the front brakes need to be done can you help me? Thanks Helen
Nov 9, 2008 at 6:41 AM
  • 110,248 POSTS
Replacing front brakes and rotors really isn't too hard. Under normal conditions, you can expect them to last approximately 25,000 miles. However, that can change based on driving habits and terrain.
To get you started, here is a link that shows in general how it is done. You can use this to help guide you in the process.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
If you look at the attachments below, they include the directions and pics specific to your vehicle for replacement. Note: The directions are for a total rebuild. If the caliper is good, bypass that section.
I hope this helps you. Let me know if you have other questions.
Apr 19, 2021 at 10:54 AM
