2003 Lexus LS 430 stuck CD in 6 disc player
75,000 MILES • V8 • 2WD • AUTOMATIC
SCOTTSM90
I have a 6 disc cd player and there is a stuck cd. I cannot get it to eject or play. Any suggestions?
Sep 26, 2009 at 1:53 PM
  • 31,937 POSTS
Hi there,
You should not try and force the CD out, as the mechanism is very delicate, i would get a radio tech to inspect this problem, most stacker's do have a manual eject button but you will need a tech to check this for you as it is just a small hole in the case which you insert a tool to manually eject the disk.
mark (mhpautos)
Sep 26, 2009 at 1:58 PM
