2002 Lexus LS 430
80,587 MILES • V8 • 4WD • AUTOMATIC
ADPSB13IPUCKL
IS IT WORTH IT TO BUY A WARRANTY FOR TWO THOUSAND DOLLARS 2000
Jun 3, 2010 at 12:24 PM
  • 31,937 POSTS
You would be well advised to read the fine print, most after market warranties are not worth the paper the are written on, check for any Claus that mentions resultant damage, this often means that if the motor is destroyed by a failed water pump , the pump is repaired but the resultant damage being the destroyed engine is not....Caveat emptor!
Mark (mhpautos)
Jun 4, 2010 at 2:19 AM
