2002 Lexus LS 430
CE WHITE
2002 Lexus LS 430
how do you remove the right hand outside mirror
Oct 31, 2009 at 6:41 AM
DAVE H
  • 13,383 POSTS
REMOVAL
REMOVE NO. 2 DOOR INSIDE HANDLE BEZEL
Using a screwdriver, remove the No. 2 door inside handle bezel.
NOTE:Tape the screwdriver tip before use.
REMOVE ARMREST BASE PANEL ASSEMBLY
Using a screwdriver, pry the armrest base panel assembly out.
HINT:
Disconnect the connector and remove the armrest base panel assembly.
REMOVE COURTESY LIGHT ASSEMBLY
Using a screwdriver, pry the courtesy light assembly out.
Disconnect the connector and remove the courtesy light assembly.
REMOVE DOOR TRIM
Remove the 7 screws.
Using a screwdriver, disengage the clips, then pull the trim upward to remove it.
Disconnect the connectors.
Disconnect the 2 cables from the inside handle and remove the door trim.
REMOVE DOOR FRAME GARNISH
Remove the 2 clips and door frame garnish.
REMOVE OUTSIDE REAR VIEW MIRROR
Disconnect the connector.
Remove the 3 bolts and outside rear view mirror.
REPLACEMENT
IF NECESSARY, DISCONNECT MIRROR
Insert the shop rag between the mirror and the mirror body to wrap up the mirror in the shop rag.
Pull up the lower side of the shop rag to disconnect the mirror joint.
Pull up the mirror and disconnect it.
CONNECT MIRROR
Connect the claws (A) and set the mirror to the mirror body.
Push the mirror to connect the claws (B) and connect it.
Mar 21, 2010 at 1:24 AM
