2001 Lexus LS 430 Adding ATF to the sealed transmission
87,000 MILES • V8 • 2WD • AUTOMATIC
MONTANABOY
Do you have a sketch showing the location of the Fill and Overflow port on the sealed transmission. Also a procedure for filling. My Lexus does not have a dipstick tube and has a very slow leak.
Jun 13, 2008 at 12:56 AM
NYC.ECHO.LEXUS.TECH
  • 20 POSTS
LEXUS HAS A SPECIAL PUMP AND ADAPTER , PLUS IF ITS SEALED NEES SPECIAL FLUID , AND THERS A PROCEDURE FOR LEVELING THE FLUID @ A CERTIAN TEMP
YOU NEED A SCAN TOOL TO READ TRANS TEMP
MUST BE DONE ACURATELY
Jan 17, 2009 at 10:38 AM
