Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lexus
LS 400
Brakes
Rotor
Replace/Remove
2000 Lexus LS 400 rear rotor removal
2000 LEXUS LS 400
150,000 MILES • V8 • 2WD • AUTOMATIC
GBANDY
MEMBER
1 POST
I have removed brake calipers and axle bolt as well as removed disc screws. Cannot get the rotor removed. What else am i missing? Thanks
Jul 19, 2008 at 6:11 AM
KHLOW2008
Experienced Mechanic
Hi gbandy,
The rotors are tightly fitted onto the hub, you need to use some rust remover and bang the area where the wheel sits to get it loosened up.
If you want to remove only the rotors, install back the axle nut first.
Jul 20, 2008 at 7:43 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine has low power
