1999 Lexus LS 400 V8 Two Wheel Drive 59000 miles
I have just replaced the brakes on all four wheels on my 99 LS 400. After doing so, I still get the brake wear warning light on my dash board.
Do you know if this must be reset in some fashion or do you believe I have a problem with the sending unit? I also had a problem with a false message for my windshield washer fluid, saying it was low when it was full. I disconnected the sending unit at the base of the reseouvour and now it does not come on.
How can I get the break wear warning signal to go off.
thanks
Jim
Friday, November 21st, 2008 AT 11:29 AM
