1998 Lexus LS 400 Trailer hitch wiring
1998 LEXUS LS 400
158,000 MILES • V8 • 2WD • AUTOMATIC
PHLORIDA
I installed a hitch to tow a small trailer and I need to wire it up now. I found the wires going back to the rear of the car but there are far more than I need and they are difficult to trace. Does anyone have the wire color codes for the running lights, turn signals, and brake lights?
Jul 14, 2009 at 3:28 AM
RACEFAN966
  • 5,029 POSTS
Ok first you will need a universal tail light converter as you have seperate turn and brake lights. So you wire to the converter and then that will leave you a 4 wire flat for the trailer. Now here is the wires in question. I will indicate wire color as such if it black the it will be blk if it is blue with an orange stribe then it will be bl/or ok. Here is is left turn is grn/blk left stop is red/wht and left tail is ppl (purple). Now right side is as follows turn is grn/yel and stop is red/wht. Now you will only need to tie into one stop and one tail or park light wire the so pick the side that is easiest then go from there. Thanks.
Jul 20, 2009 at 11:09 AM
