1996 Lexus LS 400 Tilt Wheel
1996 LEXUS LS 400
109,560 MILES • V8 • 2WD • AUTOMATIC
GTWILL
The steering wheel will move in and out but makes a ticking noise when the tilt function is activated, and will not move.
Jun 6, 2010 at 9:27 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the motor may have stripped a gear or something to that affect. You will need to pull thecovers off the column and the knee bolster most likely to get access to the motors so you can visually inspect the to see what happened and what needs to be repalced
Jun 7, 2010 at 11:19 PM
